Configuration Manager 1606 Client Cache Settings
1078
This post is an overview about Configuration Manager 1606 client cache settings. Today I installed Configuration Manager current branch 1606 on my lab setup. I installed it on Windows Server 2016 OS and used SQL 2016 to host the site database. The installation was very smooth and I didn’t face any installation errors. Version 1606 of System Center Configuration Manager brings lot of new features with it. One of the cool features includes ability to configure the client cache for Configuration Manager Clients. This was not available in previous versions of configuration manager. So if one had to change the client cache size, a powershell or VB script was used. In addition you can check this post where I showed how to increase sccm client cache using script.
The SCCM client agent downloads the content for required software once it receives the deployment. However it waits to run it until the deployment scheduled time is reached. At the scheduled time, the Configuration Manager client checks to see whether the content is available in the cache. If content is in the cache and it is the correct version, the client always uses this cached content. Therefore in such cases the “cache size” plays an important role. If the content size of an app or program is more than cache size, the deployment fails.
If you have got Configuration Manager current branch 1606, you can now configure client cache settings with ease. The default location for the client cache is %windir%\ccmcache and the default disk space is 5120 MB.
Configuration Manager 1606 Client Cache Settings Overview
Let’s now look at the ConfigMgr 1606 current branch client cache settings. Launch the configuration manager console. Click Administration > Overview > Client Settings. To change the client cache settings, you could choose a custom settings policy or a default one.
Configure client cache size – This option allows you to configure cache size. If you want to do this, set it to Yes.
Maximum cache size (MB) – With this option you can specify max cache size. By default it is set to 5120 MB, you can enter another desired value.
Maximum cache size (percentage of disk) – Use this option to specify the maximum size of the client cache folder in a percentage of disk size.
