Deploying SCCM 2012 Part 15 – Build and capture Windows 7 x64
37901
Deploying SCCM 2012 Part 15 – Build and capture Windows 7 x64 – In the Previous post, we enabled PXE support for the clients, added an operating system installer, created a task sequence. In this post we will deploy the task sequence to a new device collection and build and capture windows 7 64bit base image. This image will be deployed to the client machines.
We will first create a device collection named Build and Capture windows 7 x64. Launch the CM console, Click on Assets and Compliance. Right click Device Collections, Click on Create Device Collection.
Deploying SCCM 2012 Part 15 Snap 1
Provide a name to the collection, for Limiting Collection click on Browse and choose All Systems.
Deploying SCCM 2012 Part 15 Snap 2
click on Next, there a box that pops up, click OK.
Deploying SCCM 2012 Part 15 Snap 3
Click Close.
Deploying SCCM 2012 Part 15 Snap 4
We will now create a new Virtual machine, import the computer information precisely the MAC ID and add it to the collection. When you are creating a new virtual machine, select “I will install the operating system later“. Create a virtual machine with 1 GB as memory, 60 GB hard disk and network Adapter set to bridged mode.
Deploying SCCM 2012 Part 15 Snap 5
Power on the Virtual machine and note down the MAC Address. In the below screenshot the MAC Address is 00 0C 29 38 9B 7D.
Deploying SCCM 2012 Part 15 Snap 6
In the CM console, Click on Assets and Compliance, select  Devices and in the top ribbon click on Import Computer Information.
Deploying SCCM 2012 Part 15 Snap 7
Choose Import single computer. Click Next.
Deploying SCCM 2012 Part 15 Snap 8
Specify Computer name = WINDOWS7, MAC address = 00:0c:29:38:9b:7D. Click Next.
Deploying SCCM 2012 Part 15 Snap 9
We will add the computer to the collection that we created in the above step, click on Browse and select collection as Build and Capture Windows 7 x64. click Next.
Deploying SCCM 2012 Part 15 Snap 10
Click Close.
Deploying SCCM 2012 Part 15 Snap 11
Note : The computer that we added to the collection takes some time to show up in the collection. Proceed to the below steps only when you see the computer entry under the collection.
Deploying SCCM 2012 Part 15 Snap 12
Since the computer has been added to the Build and Capture Windows 7 x64 collection, we will now deploy the task sequence. click on Software Library, Under Operating Systems click on Task sequences.
right click the task sequence Build and Capture Windows 7 and click Deploy.
Deploying SCCM 2012 Part 15 Snap 13For the Collection, click on Browse and Select the collection “Build and Capture Windows 7 x64“. click Next.
Deploying SCCM 2012 Part 15 Snap 14
Select the Purpose as Available. Also check the box for Make available to boot media and PXE. Click Next.
Deploying SCCM 2012 Part 15 Snap 15
Do not select anything here, click Next.
Deploying SCCM 2012 Part 15 Snap 16
Deploying SCCM 2012 Part 15 Snap 17
click Next.
Deploying SCCM 2012 Part 15 Snap 18
Make no changes here, Click Next.
Deploying SCCM 2012 Part 15 Snap 19
We have successfully deployed the task sequence. click Close.
Deploying SCCM 2012 Part 15 Snap 20
Wait for few minutes and then restart the virtual machine. Press F12 to book from network.
Deploying SCCM 2012 Part 15 Snap 21
Deploying SCCM 2012 Part 15 Snap 22
Enter the PXE password. click Next.
Deploying SCCM 2012 Part 15 Snap 23
Select the Task Sequence and click Next.
Deploying SCCM 2012 Part 15 Snap 24
The hard disk is being partitioned for the installation of windows 7.
Deploying SCCM 2012 Part 15 Snap 25
Installing windows 7 OS.
Deploying SCCM 2012 Part 15 Snap 26
Preparing OS.
Deploying SCCM 2012 Part 15 Snap 27
Capturing the OS.
Deploying SCCM 2012 Part 15 Snap 28
Once the capture process is over, we can see the .wim file in the sccm server.
Deploying SCCM 2012 Part 15 Snap 29
  • Kevin T
    Hello I love your instructions btw. It has gotten me this far so far for SCCM.. I have a problem. i am at the point in this page where to create a vm in hyper-v and you mentioned to set the network adapter in bridge mode. I dont see an option to do that. Could you please clarify?
    Thanks.
  • Kevin E
    Hi, and thank you for this tutorial.
    But I have a problem.
    When WinPE is running, my task sequence don’t start. The last image I see is WinPE saying “Preparing network connections…”, and my PC just reboot.
    Thank you.
    Kevin E
    • Kevin,
      Is this error coming up on a physical machine or are you deploying it on a virtual machine ? Please you send me the smsts.log file ? You also need to check if the boot image has the NIC drivers.
    • Steven Richter
      Hi Kevin,
      you have to add the network driver in the boot Image of your task sequence. Please note that you use the right network driver for the pc you want to capture.
      Greetings
      Steven
  • Nirav Patel
    Unable to boot Windows 7 x64 capture image from SCCM 2012 on Hyper-V New Client Machine via Network boot… error says in booting window : PXE-E51 “No DHCP or DHCP Proxy Offers received” error.
    • Is the new machine able to communicate to the DHCP server ?
    • to add, use a legacy network adapter in your VM settings in order to PXE boot a Hyper-V VM.
      • Nirav Patel
        Already added legancy network adapter with specific MAC ID as well…
        How to check communication between client VM & DHCP server ??
        • Get to the DHCP server and check if it has assigned a new IP to machine..
  • rdza
    Great tutorial, but please don’t add white space on the sides of screenshots. Every time I switch between the windows, I click the white space and end up with zoomed image, it’s annoying.
  • Ganga
    Hey Prajwal..!!
    I have been looking for this information all over and atlast thank god u have posted it..!!
    Very informative..
    Cheers..!!!!
  • CMI
    Hello Prajwal,
    Your patience and expertise in creating these step by step guides/how- tos are excellent. Very much appreciated. Keep up the great work.
    Cheers!!!!!!!
  • Torstein Eriksen
    Hi!
    How long do we have to wait before the collection gets populated? Ive waited for hours.
    (Note : The computer that we added to the collection takes some time to show up in the collection. Proceed to the below steps only when you see the computer entry under the collection.)
    • It might take some time for the computer entry to show up in the collections. Did you try updating collection membership ?
  • Yes, you use the build and capture method for installing the OS first, then application and then then capture the OS. The captured OS can be used to deploy it to other machines.
  • David Baldwin
    Fantastic guide, not used SCCM for a while so dusted a few cobwebs off, now doing Build & Capture of Win 8.1 many thanks
  • Habib
    Hello Prajwal, I tried to Build and Capture Windows 7 x64 with SCCM 2012 R2, and on the Task Sequence I keep getting the error code 0x00000002 during “Prepare OS” . Please help and advise.
  • Habib
    Very Nice Guide. I have a problem with the Task Sequence during the “Prepare OS”. i got the error code 0x00000002. I was running Build and Capture win7 x64. Please help and advise.
  • Ruben Reis
    Can i create a virtual machine with some apps ex:(Adobe Reader; Fash) then capture using SCCM?
