Error 0x800706BA Failed to install Distribution Point
14144
Few months back when I was deploying the distribution point role on a windows server 2012 R2 server I came across this error Error 0x800706BA Failed to install Distribution Point when I checked the distmgr.log file. If you can see the below screenshot, you will see the line DPConnection::ConnectWMI() – Failed to connect to servername. This means that SCCM server is unable to connect to the WMI namespace on the target machine which is why the installation of distribution point is failing. You would also see an error which reads Failed to install DP files on the remote DP Error code=1722. Now let’s see how to fix this issue.
Error 0x800706BA Failed to install Distribution Point Snap1
Here is the way to fix this error. What you need to do is parse a MOF file on the target server on which you are installing the Distribution Point role. You need to look for smsdpprov.mof file which is found  in <drive:>\Program Files\Microsoft Configuration Manager\bin\X64 in your primary site server. Copy it to any drive or in a folder on the target DP server. Run the command prompt as administrator and execute the following command.
mofcomp.exe smsdpprov.mof
Note – MOF is a file extension for a Windows Management Object file format. MOF files created in the Managed Object Format have syntax based on Microsoft Visual C++.  MOF files can be compiled into the Windows Management Instrumentation (WMI) repository using mofcomp.exe.
In the below screenshot you can see that after running this command you see that MOF file has been successfully parsed.  This will create the WMI name space and after this step you should be able to install the DP without any issues. Don’t be afraid if it initially fails in the Distribution Point Configuration section in monitoring, just be patient and give it some time.
  • Ramesh
    Can I install the Distribution point on windows 7 machine ?
  • Kiran Joshi
    What are we need to check if a package is failing to install in multiple DPs. What would be the reason to fail and and How to resolve them.
    • package is failing to install in multiple DPs – You have deployed the package to DP’s or you have issues in distributing the packages to DP’s ?.
      If you are deploying the package then check execmgr.log file
  • Aussupport
    HI,
    I can see IIS was configured and distribution point installationupgrade successfully but also can see in first two line with
    Failed to install DP?
    As
    • Are you repeatedly getting that error ?. Could you post the distmgr.log file ?.
  • Is this the only error that you see in distmgr.log file ? There could be more errors in the log file as well. Please create a support thread here and attach the distmgr.log file – http://prajwaldesai.com/community
