How To Delete An Application In SCCM 2012
13599
In this post we will see how to delete an application in sccm 2012. The question is why do you want to delete the application that’s deployed to collections. The reason for deletion of application may be the users won’t require it anymore or another software might be replaced with it which has good features than the existing ones or it any be any other reason.. Well, if you try to right click the application and click delete, the application will not get deleted in SCCM 2012. There is a small procedure that you need to follow in order to delete the application. Lets take a look at it.
Launch the ConfigMgr Console, Click on Software Library, Application Management, Applications. In the previous post we had deployed Office 2010 using sccm to a collection. In this post we will be deleting this application from our sccm server.
How To Delete An Application In SCCM 2012 Snap 1
When we right click the application and select Delete, we get a warning message box. It clearly shows that the number of active deployments is 1 which means the application is deployed once. Click OK.
How To Delete An Application In SCCM 2012 Snap 2
Before we delete the application its recommended to retire that application. To do so right click the application and click Retire.
How To Delete An Application In SCCM 2012 Snap 3
Next we click on Deployments and we see that the application is deployed to a collection named All Windows 7 Systems. Right click the Collection and click Delete.
How To Delete An Application In SCCM 2012 Snap 4
Right click the Application and click Revision History.
How To Delete An Application In SCCM 2012 Snap 5
On the Application Revision History window, start deleting the revisions from the bottom.
How To Delete An Application In SCCM 2012 Snap 6
Delete all the revisions one by one.
How To Delete An Application In SCCM 2012 Snap 7
Once you have deleted all the revisions, right the application and delete it. You get a warning box, click Yes to delete the app permanently.
How To Delete An Application In SCCM 2012 Snap 8
  • Jimmy Mooves
    Hi Prajwal, Firstly great blog! Secondly, if you right click and delete the application before you remove the revision history it appears that these revisions remain in the content library (filestore). Is there a utility or exe that I can run that can remove orphaned folders?
    Thanks,
    Jimmy
    • Hey Jimmy, good question. I haven’t come across any such utility.
  • Bar
    On SCCM there is a term called Application Supersedence, which we can do replace an application on the client with another application or with new version of the same application. To perform the supersedence we must uninstall the current application firstly, then we can do to deploy a new application to the clients.
    Can we uninstall a client application from SCCM, or we must do it manually on client systems?
    Thanks.
    • When you supersede an application, you can specify a new deployment type to replace the deployment type of the superseded application and also configure whether to upgrade or uninstall the superseded application before the superseding application is installed.
  • Abdul
    How do i create inbuilt reports ?
  • Zaid
    Hi Prajwal, I like your website.
  • Parthiban Selvaraj
    Hi
    Am new to scccm. We are using sccm 2012. I have some doubt, can i able to uninstall software by using sccm 2012 which software does not install by using sccm.
    can i able to use third party software if possible please suggest me any good third party tool.
  • rebellionemesis
    Nice article, but if I can ask – what happens to the software distributions that you have when initially creating the software.
    Does that get removed automatically as well… I normally do this task manually but if there is any way to automate it – then I’d be very interested in knowing this.
