How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta
2100
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta In this post we will upgrade SCCM 2012 RTM to SCCM 2012 SP1 beta. The Configuration Manager 2012 SP1 Beta was released by Microsoft which allows you to deploy and update Windows 8 apps alongside your existing native and virtual applications. SP1 will support the deployment and management of Windows to Go USB drives, as well as enable you to more easily manage policies for new Windows 8 client-side caching, roaming user profiles, and folder redirection features.
Configuration Manager SP1 enhancements include:
1) Deployment and management of Windows 8 and Windows Server 2012.
2) Distribution point for Windows Azure to help reduce infrastructure costs.
3) Automation of administrative tasks through PowerShell support.
4) Management of Mac OS X clients and Linux and UNIX servers.
Note : If you have installed an earlier prerelease version of System Center 2012 Configuration Manager SP1, uninstall it before you install System Center 2012 Configuration Manager SP1 Beta. Before you start upgrading please take a look at Release Notes for the System Center 2012 Configuration Manager Service Pack 1 Beta.
The Configuration Manager 2012 SP1 beta can be downloaded at :- http://www.microsoft.com/en-us/download/details.aspx?id=34607
Note : In this post we will be upgrading the existing CM 2012 to CM 2012 SP1 Beta. Since this is a beta version try this on a lab setup and not on Production Server. Perform the below steps with user account that is a member of domain admins group. There is already a SCCM 2012 RTM server running for which this upgrade will be installed.
After Downloading the file ConfigMgr_SCEP_2012_SP1_Beta_ENU_7782, extract it to a folder. Open the folder and run the file splash.hta. Click Install.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 1
Choose Upgrade this Configuration Manager Site. Click Next.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 2
We will install the evaluation edition of this product.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 3
Read the license terms and click I Accept these license terms. Click Next.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 4
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 5
We will download the prerequisite files and place them into a folder called updates.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 7
Click Next on Server Language Selection Page.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 9
Click next on Client Language Selection Page.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 10
The Setup type is Upgrade, click Next.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 11
We see that there is 1 warning message related to WSUS. The upgrade requires USMT, WDT, WinPE to be installed.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 12
Download and run adksetup.exe. The file can be downloaded from here : http://www.microsoft.com/en-us/download/details.aspx?id=30652. Double click the file to start the installation.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 13
Read the License Agreement and click Accept.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 15
We will select Application compatibility toolkit, Deployment Tools, Windows PE, USMT. click on Install.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 17
After sometime we see that the selected features are installed.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 18
As per the warning, Configuration Manager requires KB2720211 and KB2734608 to be installed. KB2720211 can be downloaded here, KB2734608 can be downloaded here. Once installed run the check again. If there are no warnings or errors click Begin Install.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 19
The Configuration Manager 2012 SP1 Beta upgrade completed successfully.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 20
Click View Log to see the logs of the CM setup. We can see that CM 2012 server setup – upgrade has been completed successfully.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 21
Launch the Configuration Manager Console,click on the down arrow at top left corner of the console and click on About Configuration Manager.
How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 24How to Upgrade SCCM 2012 RTM to SCCM 2012 SP1 Beta Snap 25
  • Charlie
    Amazing posts I must say… Good work.
