Installing Active Directory Domain Services for SCCM
9290
Installing Active Directory Domain Services for SCCM After setting up the lab we can now proceed to install the Active Directory on the server machine. Installing Active Directory Domain Services Active Directory is a directory service created by Microsoft for Windows domain networks. Server computers that run Active Directory are called domain controllers. An AD domain controller authenticates and authorizes all users and computers in a Windows domain type network assigning and enforcing security policies for all computers and installing or updating software.
Installing Active Directory Domain Services for SCCM -In this post the Active Directory Domain Service role will be installed on Windows Server 2008 R2.
On the Task bar click on Server manager to bring up this window. Click on Add Roles
Active Directory Domain Services Snap 1
Select Active Directory Domain Services from list of Roles
Deploying SCCM 2012 Part 1 Snap 2
Click on Add Required Features
Deploying SCCM 2012 Part 1 Snap 3
This page provides information about Active Directory Domain Services. Click on next.
Deploying SCCM 2012 Part 1 Snap 4
Selections that you made during the above steps is shown on the confirm installation selection page. Click on Install to proceed.
Deploying SCCM 2012 Part 1 Snap 5
The Active Directory Domain Service role is yet to be installed, so click on “Close this wizard and launch Active Directory…” to start the setup. You can also run dcpromo to initiate the ADDS setup.
Deploying SCCM 2012 Part 1 Snap 6
Select “Use Advanced Mode Installation” and click Next.
Deploying SCCM 2012 Part 1 Snap 7
click Next.
Deploying SCCM 2012 Part 1 Snap 8
We will be creating a new domain in the new forest. Choose Create a new domain in a new forest.
Deploying SCCM 2012 Part 1 Snap 9
for this lab the domain name will be PRAJWAL.LOCAL
Deploying SCCM 2012 Part 1 Snap 10
A NetBIOS Name is a unique identifier, up to 15 characters long with a 16th character type identifier, that NetBIOS services use to identify resources on a network running NetBIOS over TCP/IP (NetBT). NetBios name for my lab will be PRAJWAL.
Deploying SCCM 2012 Part 1 Snap 11
Select Windows Server 2008 R2 as forest functional level and click next.
Deploying SCCM 2012 Part 1 Snap 12
The DNS server will be installed on the same machine
Deploying SCCM 2012 Part 1 Snap 13
The Active Directory database is stored in a file called NTDS.dit. The log files are stored in a separate file called NTDS.log. SYSVOL provides a standard location to store important elements of Group Policy objects (GPOs) and scripts so that the File Replication service (FRS) can distribute them to other domain controllers within that domain.
Deploying SCCM 2012 Part 1 Snap 14
Directory Services Restore Mode (DSRM) is a special boot mode for repairing or recovering Active Directory. It is used to log on to the computer when Active Directory has failed or needs to be restored. Provide a complex password and click next.
Deploying SCCM 2012 Part 1 Snap 15
Deploying SCCM 2012 Part 1 Snap 16
Check Reboot on Completion.
Deploying SCCM 2012 Part 1 Snap 17
Wait for sometime to complete the installation After the reboot, once you Login, Under system properties you will find your domain name.
Deploying SCCM 2012 Part 1 Snap 18
Congratulations, you have successfully installed Active Directory Domain Services.
  • Akram
    Good Work –
    I need you to explain for me sccm 2012 service account and/or A.D account that needed for installation and waht steps to do it
    thank you
  • Senthil
    Excellent article for learning SCCM. Good work Prajwal.
  • Neerja
    Great work!! I’m learning SCCM from your article!! Thanks Prajwal!!
  • Nitin
    Nice article for learning SCCM Prajwal,
    Small Suggestion
    Please Add link of Next Part and Previous Part at the End of the page, It’s easy to follow and Learn.
  • Gopi
    Excellent article about SCCM
