SCCM Configuration Manager Build Version Numbers
This post lists all the SCCM Configuration Manager Build Version Numbers and Current Branch. Looking at SCCM build numbers you can observe that there have been a number of significant releases in the past years. The SCCM version numbers changes with every update. Here is an attempt to list all the SCCM Configuration Manager build version numbers. The link to download cumulative updates have been provided in the table. I will be updating this post as the new versions are released.
To check the console and site version simply open the Configuration manager Console, click the blue tab in the top left corner and press About Configuration Manager.
If you’d like to know the CU version you need to check the registry on the site server. Open the Registry Editor and browse to HKLM \Software\Microsoft \SMS\Setup
System Center Configuration Manager Current Branch
NameVersion & Build NumberKB (If any)
SCCM Technical Preview (Update 1609)5.0.8445.1000
SCCM Technical Preview (Update 1608)5.0.8433.1000
SCCM 1606 Early Wave Update5.0.8412.1204KB3180992
SCCM Technical Preview (Update 1607)5.0.8426.1000
SCCM Technical Preview (Update 1606)5.0.8410.1000
SCCM Technical Preview (Update 1605)5.0.8396.1000
SCCM Technical Preview 4 (Update 1604)5.0.8385.1000
SCCM Technical Preview 4 (Update 1603)5.0.8372.1000
SCCM Update 16025.0.8355.1000
SCCM Technical Preview 4 (Update 1602)5.0.8360.1000
SCCM Technical Preview 4 (Update 1601)5.0.8347.1000
SCCM Technical Preview 4 (Update 1512)5.0.8336.1000
SCCM Update 15115.0.8325.1000
SCCM Technical Preview 4 (Update 1511)5.0.8325.1000
SCCM Technical Preview 3 (Update 1510)5.0.8315.1000
SCCM Technical Preview 3 (Update 1509)5.0.8299.1000
SCCM Technical Preview 35.0.8287.1000
SCCM Technical Preview 25.0.8271.1000
SCCM Technical Preview5.0.8239.1000
NameBuild NumberKB (if any)
SCCM 2012 R2 SP1 CU35.0.8239.1403KB3135680
SCCM 2012 R2 SP1 CU25.00.8239.1301KB3100144
SCCM 2012 R2 SP1 CU15.00.8239.1203KB3074857
SCCM 2012 R2 SP15.00.8239.1000
SCCM 2012 R2 CU55.00.7958.1604KB3054451
SCCM 2012 R2 CU45.00.7958.1501KB3026739
SCCM 2012 R2 CU35.00.7958.1401KB2994331
SCCM 2012 R2 CU25.00.7958.1303KB2970177
SCCM 2012 R2 CU15.00.7958.1203KB2938441
SCCM 2012 R2 Hotfix5.00.7958.1101KB2905002
SCCM 2012 R2 RTM5.00.7958.1000
  • K.Sace
    What is the differance between System Center Configuration Manager 2012 R2 & System Center Configuration Manager Current Branch ?
  • Chetan.Gawali
    I am facing issue with compliance report. the issue is some of the systems showing in compliance but when I check on that systems patches is not available on that system but showing in compliance.
    some systems showing in non compliance but patches are installed.
    please help me in this
    checked all database and SUP replication related logs but no error.
