Best Guide to Configure SCCM 2012 Firewall Exceptions
Posted by Prajwal Desai
In this post I will cover two important concepts. The first one is installing WSUS and the second one SCCM 2012 firewall exceptions. I must tell you that you can install WSUS after installing SCCM as well. You might see a warning during SCCM 2012 prerequisite check. However I prefer to install it before installing SCCM.
Configuring firewall exceptions is yet another important thing. We will look at opening SQL ports for SCCM. There are few services that needs to be allowed through windows firewall to ensure client installation works fine.
Installing WSUS 3.0 SP2
As a first step let’s install WSUS. When you want SCCM to deploy software updates, SCCM uses WSUS to download the metadata. In addition to that, when you install the active software update point on a remote site system, you must install the WSUS Administration Console on the site server computer. This allows the site server to communicate with WSUS running on the active software update point.
Installing WSUS is quite simple. You can install WSUS by opening up the server manager, roles and by adding WSUS role. I prefer to install the WSUS by downloading the setup file from Microsoft.
Run the WSUS Setup file. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 1
Select Full server installation including the administrator console. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 2
Always place the updates on different drive. We will place WSUS updates on the drive named E:. You can store the updates on C drive but it is not recommended because C: drive is meant for OS. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 3
Select the SQL database instance. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 4
We see the connection to SQL server is successful. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 5
Select Use existing IIS default Web site and click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 6
Finally, click Finish to complete the WSUS installation.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 7
Here is very important note. Once you click Finish, the WSUS configuration wizard comes up. Do not configure anything here. Click cancel to close the wizard.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 8
We will now configure firewall to allow ports that are essential for SCCM client installation. In order to successfully push SCCM client agents to machines, you must add the following as exceptions to the Windows Firewall.
  • Printer Sharing
  • Windows Management Instrumentation (WMI)
Create Inbound Rule – File and Printer Sharing Service
We will create an inbound and outbound rule, add File and Printer sharing service as exception to firewall . An inbound rule to allow WMI. We will perform this activity on the Domain Controller.
Open group policy management console. Right click Domain and create a GPO.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 9
Specify a name to this policy such as SCCM Client Push Policy. Click OK. Right click the SCCM Client Push policy and click Edit.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 10
Expand computer configuration, Windows settings, Security settings, Windows firewall with advanced security. Refer the below screenshot.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 11
Right click Inbound Rule and select New Rule. Select Predefined and select File and Printer Sharing from the list. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 12
Select all Rules. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 13
Check the radio button Allow the Connection and click Finish.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 14
Our Inbound Rule is created.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 15
Create Outbound Rule – File and Printer Sharing Service
Now we will create an outbound rule for the same.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 16
Make sure all the rules are selected. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 17
Select Allow the Connection. Click Finish.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 18
We have created a rule to allow the File and Printer sharing Outbound.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 19
Create Inbound Outbound Rule – Windows Management Instrumentation
Now we will create an Inbound Rule to allow Windows Management Instrumentation. Create an inbound rule selecting Windows Management Instrumentation from predefined. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 20
Check all the rules and click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 21
Allow the connection. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 26
SQL Ports for SCCM
Next we will open TCP port 1433 and 4022 for SQL replication. By default, Microsoft Windows enables the Windows Firewall, which closes port 1433 to prevent Internet computers from connecting to a default instance of SQL Server on your computer. Connections to the default instance using TCP/IP are not possible unless you reopen port 1433. Let’s create a group policy to open TCP ports 1433 and 4022.
Open the Group Policy Management console. Create a new policy and name it as SQL Ports for SCCM 2012. Right Click the policy SQL Ports for SCCM 2012 and click Edit.
In the Windows GP management console, expand computer configuration, Windows settings, Security settings, Windows firewall with advanced security.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 23
SQL Ports – Open TCP Port 1433
Create an Inbound Rule and select Port. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 24
Select TCP, and specify port 1433 in specific local ports. Click Next.
SQL Ports for SCCM - TCP port 1433
Click Allow connection and click Next.
The firewall rule will be applied for all the 3 profiles. Click Next.
  • Domain
  • Private
  • Public
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 32
Specify a rule Name. Click Finish.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 28
SQL Ports – Open TCP Port 4022
We will now open the TCP port 4022. Create an Inbound Rule and select Port. Click Next.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 29
Specify the port number as 4022. Click Next.
SQL Ports for SCCM
Choose Allow the connection.
Deploying SCCM 2012 Part 5 – Installing WSUS Snap 31
This rule applies to all the 3 profiles, click Next.
Specify a rule name and click Finish.
SQL Ports for SCCM
The rules that we created can be seen in the inbound rules section.
SQL Ports for SCCM - TCP port 4022
Share This Article
Follow:
10 Comments
