Best EFS Alternative for Encrypting Sensitive Files Automatically
0 54
This post is a review about a software called Lock My Folders. You would have guessed by now that it basically locks the software ?. There is more to it, Lock My Folders is the best EFS alternative for encrypting sensitive files automatically. This software uses data encryption and lets you lock and password-protect folders or files, encrypt your important files on the fly.
In simple terms, encryption is the process of converting information or data into a code, especially to prevent unauthorized access. With Lock my folders tool, encryption is automatic and real-time, without affecting computer performance. Locking a folder is pretty easy. One of the good feature of this tool is you can prevent access to your secure folders in safe mode. Performance of this tool is great and any novice user will find this tool very easy to install and use.
To download Lock My Folders software click this link. The software is compatible with Windows 10/8/7 operating systems.
Lock My Folders – Key Features and Benefits
  • The software is very ease to use.
  • Using simple way you can hide or lock your important folders & files.
  • You secure your Windows folders / files by encrypting them on the fly.
  • Copying any files in the protected folder will be encrypted automatically.
  • The software is written so well that you can encrypt your folders/files without performance loss.
  • No one uninstall Lock My Folders program without your password.
Install Lock My Folders – Best EFS Alternative for Encrypting Sensitive Files Automatically
First of all download the Lock My Folder from here. Run the executable and follow the wizard to install the software. Select the destination location and click Next.
Click Install.
To complete the installation, click Yes restart the computer now. Click Finish.
On the first launch, you have to set a new password for this program. Set a complex password and click OK. remember that every time you launch this software, the password is required to use the software.
Now let’s lock a folder. Click Add button and type a folder name and choose the location of that folder. The folder that you are creating is a secure folder. Click OK.
Once you add the folder, click Lock button. Now you can see that the status is changed to Locked. This means you have created a secure folder and the folders and files within it are completely encrypted.
If you attempt to open this folder you get permission denied message. This means the folder is completely protected by this software.
To simply unlock the folder, go to the folder location. Right click folder and click Unlock My Folder.
You will be asked to enter the password. To unlock the folder enter the password and click OK.
If you click Settings, you will notice some good options that this tool has.
  • Prevent access to your secure folders in safe mode.
  • Hide secure folders when they are locked.
  • Add “Lock My Folder” to windows explorer context menu.
This software can be uninstalled by going into Settings > Uninstall tab. Click Uninstall “Lock My Folders” software to cleanly uninstall this software.
93%
Lock My Folders Tool Review
Lock My Folders is an automate data encryption software that lets you lock and password-protect folders or files, encrypt your important or confidential files on the fly. Encryption is automatic and real-time, without affecting computer performance.
  • Installation
  • Ease of Use
  • Configuration
  • Cost
