So far I have dealt with numerous client agent installation issues. Some of them were simple and some of them were really tough to troubleshoot. I have always documented then under SCCM troubleshooting category. Thanks to log files that keep us helping every time. What log file to analyze when, comes with experience. Most of the time the SCCM client agent install fails due to issues local to client machine. In this post we will talk about client agent installation issue – CcmSetup is exiting with return code 7.
The user mentioned that SCCM agent is installing but not completely. The Configuration Manager client Actions tab showed only two cycles.
- Machine Policy Retrieval & Evaluation Cycle.
- User Policy Retrieval & Evaluation Cycle.
In one of my post, I covered in detail about Configuration Manager Client Actions. If you find only those two actions, you have to really dig the log files to see what’s happening. While it takes some time to see other action cycles, don’t panic if you initially see only those action cycles.
Checking the ccmsetup.log file revealed something important. At the end was the line CcmSetup is exiting with return code 7. I had not seen this return code 7 before. Also there is not much info about this on internet. However I found Jason had blogged about this issue. He also documented the SCCM client agent installation error codes. That was really helpful in understanding what the return code 7 meant.
StartServices. Starting services
CcmStartService. Starts the ccmexec service.
Successfully deleted the ccmsetup service
Deleted file C:\Windows\ccmsetup\ccmsetup.xml
Task 'Configuration Manager Client Upgrade Task' does not exist ccmsetup
CcmSetup is exiting with return code 7 ccmsetup
Referring to the same post, return code 7 translates to reboot required. That was crazy to hear but why a reboot ?. In my opinion it could be a pending system reboot that was required. Or as Jason mentioned it could be .NET Framework installer that was requesting a reboot. Rebooting the client machine brought back all the missing action cycles. Finally the SCCM client agent was seen active in console.
