Deploy Office 2019 using SCCM [Using Office Deployment Tool]
25
In this post I will cover the steps to deploy Office 2019 using SCCM. Office 2019 is released along with new version of Office Deployment Tool. The Office 2019 is released for both Windows and Mac OS. Recently I published a post on Office 2019 overview and deployment info. Please read that post before you plan to deploy Office 2019 using SCCM. Office 2019 uses only click-to-run installation technology. We know about this because Click-to-Run has been the installation technology for most Office products since the release of Office 2013.
The important question is should i deploy Office 2019 or go with Office 365. First of all if you have deployed Office 365 ProPlus to the users in your organization, you don’t need Office 2019. This is because most of the features introduced in Office 2019 are already covered in Office 365 plans. My preference would be still Office 365 as you get updates frequently. Office 2019 is a software that is available as one time purchase. You can buy it from either online store or through volume license agreement. However you can expect only security updates for Office 2019 in future. Let’s proceed with deploying Office 2019 using Configuration Manager.
Step 1 – Install Office Deployment Tool
Download the office deployment tool from here. Right click the executable and run as administrator. You will now see Microsoft Office 2016 click-to-run administrator tool. Accept the license terms and click Continue.
Create a new folder such as Office 2019 within sources folder and select the folder. Click OK. The executable extracts setup and configuration files inside the selected folder.
There are three files present in the folder.
  • configuration-Office365-x64.xml
  • configuration-Office365-x86.xml
  • setup.exe
Step 2 – Create Configuration File
In the next step create a new text file and rename it as config.xml. Well, you can name it anything but ensure you specify .xml as extension. This file should be in the same folder where the setup and other config files are present. Here is a sample configuration file that you can use it with office deployment tool. In my case I used the below configuration file. This configuration file downloads Office 2019 32-bit version. In addition the previous Windows Installer versions of Office are removed as part of the installation process. The PIDKEY is the product key for MAK activation. You don’t need to use PIDKEY if you’re activating Office 2019 with Key Management Service (KMS).
<Configuration>
<Add SourcePath="\\corpsccm\Sources\Applications\Office 2019" OfficeClientEdition="32" Channel="PerpetualVL2019">
<Product ID="ProPlus2019Volume" PIDKEY=" " >
<Language ID="en-us" />
</Product>
<Product ID="ProofingTools">
</Product>
</Add>
<RemoveMSI All="True" />
<Display Level="None" AcceptEULA="TRUE" />
<Property Name="AUTOACTIVATE" Value="1" />
</Configuration>
Step 3 – Download the Office 2019 installation files
In this step we will download Office 2019 installation files. Run the command prompt as administrator. Change the path to Office 2019 folder. Type the command setup.exe /download config.xml and press enter.
The Office 2019 installation files are downloaded and placed inside Office folder. The approx size of this folder after download is around 2.12 GB.
Step 4 – Deploy Office 2019 using SCCM
We will now deploy Office 2019 using SCCM. Launch SCCM console and create a new Application. On the General page, select Manually specify the application information. Click Next.
Specify some information about Office 2019 application and click Next.
Add a new deployment type and on General page, select Manually specify the deployment type information. Click Next.
Specify the content location. This is the folder where Office 2019 setup files are present along with setup and config files. Next, specify the installation program as per below format.
"\\server\share\setup.exe" /configure config.xml
Note – I will update the uninstall command at later point of time.
Since I will be deploying Office 2019 to both 32-bit and 64-bit OS, I am going to check the box “Run installation and uninstall program as 32-bit process on 64-bit clients”.
Adding a detection method is really important here. Add the Office 2019 detection method with following settings.
  • Setting Type – Registry
  • Hive – HKEY_LOCAL_MACHINE
  • Key – SOFTWARE\Microsoft\Office\ClickToRun\Configuration
  • Value – VersionToReport
  • Enable “This registry key is associated with a 32-bit application on 64-bit systems”
  • Data Type – Version
  • Select “This registry setting must satisfy following rule to indicate the presence of this application”
  • Operator – Greater than or equal to
  • Value – 16.0.10336.20044
Click OK to close detection rule box. Click Next.
Specify the user experience settings for the application. Click Next.
Note that Office 2019 is compatible with Windows 10 OS only. Therefore you have to specify the OS requirements here. Click Next.
On the Completion page click Close. This will close create application wizard.
Deploy Office 2019 using SCCMYou have now packaged Office 2019 application. Finally deploy the Office 2019 to a device collection.
In my lab setup, i could install Office 2019 without any issues. Open the software center and select Office 2019 app and click Install. Monitor the installation progress by opening AppEnforce.log file.
  • This comment is not related to this post. I am a big fan of your blog and read it from time to time.
    I found below discrepancy in SCCM quiz questions part 1 and part 3:
    Question 7 from part 1 and question 11 from part 3 are the same yet the answers for both the questions are different. Please do check it out if you get some time.
    Below are the links for the part 1 and part 3 quiz questions.
    https://prajwaldesai.com/sccm-configuration-manager-quiz-questions-part-1/
    https://prajwaldesai.com/sccm-configuration-manager-quiz-questions-part-3/
  • I am running into an issue, it is definitely downloading without issue but it says
    invalid executable file “\shareOffice2019setup.exe”
    enforce app failed (0x87d01106)
    failed to invoke enforceapp on application handler (0x87d01106)
    failed to enforce app, error 0x87d01106
    we are running office 2016 pro plus now. So my question i guess is the registry stuff you included in your example not going to make this work.
  • So if I use my installation package with the flag to remove all previous installed software like follows it works:
    If I tell the setup to leave previously installed Visio or Project versions like follows it fails:
    Any idea what might be wrong? The installation log is really one of the worst ever … no clear failure message (at least for me). Thanks.
    • I still havent gotten this to work. It fails when trying to run the executable.
      here is what the appenforcer log says, ive been stumbling on this for about a week now. Any direction would be greatly appreciated
      ++++++ App enforcement completed (8 seconds) for App DT “Office Professional Plus 2019 Test I Drive” [ScopeId_53BF64D9-F1F5-4EAD-9EDC-A7A04A2B3A22/DeploymentType_d0b1e7fc-d117-493b-b25f-35666f1725f9], Revision: 2, User SID: ] ++++++ AppEnforce 10/8/2018 1:39:51 PM 5236 (0x1474)
      +++ Starting Install enforcement for App DT “Office Pro Plus 2019 Test SCCM test only” ApplicationDeliveryType – ScopeId_53BF64D9-F1F5-4EAD-9EDC-A7A04A2B3A22/DeploymentType_d5246753-be0e-4ea0-b20b-a5ac6e7684ac, Revision – 3, ContentPath – C:WINDOWSccmcachem, Execution Context – System AppEnforce 10/8/2018 2:12:46 PM 32 (0x0020)
      Performing detection of app deployment type Office Pro Plus 2019 Test SCCM test only(ScopeId_53BF64D9-F1F5-4EAD-9EDC-A7A04A2B3A22/DeploymentType_d5246753-be0e-4ea0-b20b-a5ac6e7684ac, revision 3) for system. AppEnforce 10/8/2018 2:12:46 PM 32 (0x0020)
      +++ Application not discovered. [AppDT Id: ScopeId_53BF64D9-F1F5-4EAD-9EDC-A7A04A2B3A22/DeploymentType_d5246753-be0e-4ea0-b20b-a5ac6e7684ac, Revision: 3] AppEnforce 10/8/2018 2:12:46 PM 32 (0x0020)
      App enforcement environment:
      Context: Machine
      Command line: setup.exe /configure configure.xml
      Allow user interaction: No
      UI mode: 0
      User token: null
      Session Id: 1
      Content path: C:WINDOWSccmcachem
      Working directory: AppEnforce 10/8/2018 2:12:46 PM 32 (0x0020)
      Prepared working directory: C:WINDOWSccmcachem AppEnforce 10/8/2018 2:12:46 PM 32 (0x0020)
      Prepared command line: “C:WINDOWSccmcachemsetup.exe” /configure configure.xml AppEnforce 10/8/2018 2:12:47 PM 32 (0x0020)
      Post install behavior is BasedOnExitCode AppEnforce 10/8/2018 2:12:47 PM 32 (0x0020)
      Waiting for process 1660 to finish. Timeout = 120 minutes. AppEnforce 10/8/2018 2:12:47 PM 32 (0x0020)
      Process 1660 terminated with exitcode: 2147549183 AppEnforce 10/8/2018 2:12:51 PM 32 (0x0020)
      Looking for exit code -2147418113 in exit codes table… AppEnforce 10/8/2018 2:12:51 PM 32 (0x0020)
    • Hi, I use the following so far:
      Project – 32-Bit: %programfiles(x86)%Microsoft OfficerootOffice16WINPROJ.EXE
      Project – 64-Bit: %ProgramFiles%Microsoft OfficerootOffice16WINPROJ.EXE
      Project – 32-Bit: %programfiles(x86)%Microsoft OfficerootOffice16VISIO.EXE
      Project – 64-Bit: %ProgramFiles%Microsoft OfficerootOffice16VISIO.EXE
  • Wondering what the effect of installing Office 2019 on an existing Office 365 installation. I’m guessing the Detection Logic will allow the installation based on Version but will Office 2019 uninstall Office 365 to you knowledge?
  • Hi. Great guide. Was able to set up Office 2019 in my lab. Just wondering how to deploy the updates to this. We clearly will not want Internet Updates but rather update via SCCM if that’s offered. Having some slight issues with adding all languages
    • There won’t be much updates for Office 2019, there shall be only security updates. I am sure the future updates can be still deployed via SCCM. May i know what issues are you facing wrt adding languages ?.
      • At the moment with application languages where it remains en-US only despite having added French and German too. For the proofing tool it works … but still experimenting 🙂 I’m sure might just be a space too much somewhere.
      • Redid a brandnew package and now all languages are properly available … now having issue to activate despite having added the KMS key to our KMS host 🙁 (always something).
  • According to Microsoft, The Office 365 Management section should allow you to deploy and manage Office 2019. But it does not appear to be updated with this capability yet. Will you cover this method when it is updated? This seems the most logical way to deploy it from what I can see? All my customers are VL, so no Office 365. Therefore never used the 365 management interface.
      • Thanks for the reply. I hope they get it updated soon. They seem to be dragging their heels on this one. Still waiting for some of my OVS customers to get Office 2019 keys assigned!
