Patch Connect Plus – Supercharge your Third party applications patching
This post talks about an interesting tool called Patch Connect Plus. Patch Connect Plus is a tool that helps deploy patches to over 250 third party applications. I get many queries on how to keep third party apps updated. A lot of organizations today use SCCM to deploy windows updates. However one of the limitations of SCCM is its inability to patch non Microsoft applications.
Imagine an organization has got around 50 different third party applications deployed. How would the IT ensure all the third party applications are patched ?. Patching third party apps becomes inconvenience for IT admins in such cases. One has to look for other tools in addition to SCCM for deploying third party applications. This is not only time consuming but becomes more tedious as the list of applications grows.
Well if you are in similar situation, this post will help you out. Patch Connect Plus integrates very well with Microsoft SCCM server. It allows you to patch third party applications. You can customize your deployment and view the complete SCCM deployment data. Furthermore Patch Connect Plus also provides an option to publish patches via SCUP catalog. Using SCCM plugin, users now can access and deploy the entirety of third-party applications supported by Patch Connect Plus directly from the SCCM Console.
Patch Connect Plus
Manage Engine Patch Connect Plus Setup
This tool helps deploy patches for applications such as Adobe, Java and WinRAR using your existing SCCM server. These are some of the basic apps that are used in most of the organizations. You can download the tool by clicking here. You get 30 day trial copy with all the features enabled. Of course before you setup the tool, check the hardware requirements and other prerequisites.
Patch Connect Plus is available in two variants. Patch Connect Plus for Microsoft SCCM and Patch Connect Plus for Microsoft SCUP. Take look at comparison matrix here.
Patch Connect Plus – Top features of Patch Connect Plus
We have talked about what is Patch Connect Plus and what it does. In this section we will see some top notch features of this tool.
Easy Installation and Setup
First of all installing and setting up patch connect plus tool is very easy. You install the tool on a member server and the wizard takes you through configuration. Integrating SCCM, connecting to WSUS and assigning certs are the major steps. Most of all the configuration part is simple and doesn’t take much time to setup this up. Post setup using wizard you can configure following things.
  • Model Select – Can be either SCUP catalog or SCCM infrastructure.
  • Proxy Settings.
  • WSUS Configuration.
  • Certificate Settings.
  • Select Applications.
  • SCCM Settings.
Broadest third party patches database
ManageEngine maintains a huge database of third party updates. The database can be synchronized manually or can be scheduled. Updating the applications in a big organization is more time consuming. The tool supports patching for more than 300+ non-Microsoft apps. All this can be done using your SCCM server.
Patch Connect Plus
Deployment Customization
The usual way of deploying an application is package the app and then deploy. You can customize the deployment of 3rd party patches by creating deployment templates with ease. Once these templates are created, you can retain the templates and map them to different deployments.
These are a few examples of customization available.
  • Skip the deployment if the application is already running.
  • Uninstall recent old updates before deploying the new updates.
  • Don’t display application icon in start menu after successful patch deployment.
  • Do not add application task bar icon after successful patch deployment.
  • Do not add application shortcut on the desktop after successful patch deployment.
Patch Connect Plus
Easy SCCM Integration
You can easily integrate the tool with Configuration Manager. The wizard requires basic SCCM server info and connects to SCCM. After integration, you can deploy third-party applications supported by Patch Connect Plus directly from the SCCM Console.
Patch Connect Plus
Deployment data report
The report offers insights on:
  • All the missing patches in a system.
  • All the systems in which a particular patch is missing.
  • Missing system/Failed system/Installed system details.
Always stay ahead of third party updates
If you are using SCUP to deploy third party updates, you need not worry here. Because synchronization with ManageEngine’s central patch repository happens everyday. Hence new updates are readily available for your systems.
