This post has got list of all current branch SCCM build numbers. The old versions of SCCM build numbers are documented here. We know that there are many SCCM versions released in past years. The SCCM build numbers changes with every update. In this post I will list all the SCCM Configuration Manager build version numbers. The link to download cumulative updates have been provided in the table.
Most of all you can easily find out the SCCM version that you are using. To find the console and site version simply open the Configuration manager Console. Click the blue tab in the top left corner and press About Configuration Manager.
If you’d like to know the CU version you must check the registry on the site server. Open the Registry Editor and browse to HKLM\Software\Microsoft\SMS\Setup.
Configuration Manager Current Branch SCCM Build Numbers
So here is a list of SCCM build numbers. The SCCM build numbers table shall be updated as and when the new builds are released. In the coming days, I will add installation guides for each of the major update.
NameVersionKB (If Any)
SCCM 18065.00.8692.1000
SCCM 1802 UpdateKB4132447
SCCM 18025.00.8634.1000
SCCM 1710 Update Rollup 25.00.8577.1115KB4086143
SCCM 1710 Update Rollup 15.00.8577.1108KB4057517
SCCM 17105.00.8577.1000
SCCM 1706 Update Rollup 15.00.8540.1611KB4042949
SCCM 17065.00.8540.1000
SCCM 17025.00.8498.1000
SCCM 16105.00.8458.1000
SCCM 16065.00.8412.1000
SCCM 1606 Early Wave Update5.00.8412.1204KB3180992
SCCM Update 16025.00.8355.1000
SCCM Update 15115.00.8325.1000
  • I am having issues with updating to 1802. Its been about a month and my SCCM server is still downloading 1802. Plz help.
