SCCM Configuration Manager Technical Preview Build Numbers
This post lists the SCCM Configuration Manager Technical Preview build numbers. Microsoft adds new features in each version of technical preview. This is just an insight of what’s coming up in next release of SCCM current branch. However Microsoft allows you to try the tech preview version. The users can test it on their lab setup and provide feedback. To use the technical preview you must first install a baseline version of the technical preview build. Once you install the baseline version, use the in-console updates to update to the latest one.
Note – The SCCM Configuration Manager Technical Preview versions must be tested only in a lab environment. There shall be no support provided from Microsoft for tech preview versions. Click this link that takes you to Configuration Manager feedback program page on the Microsoft Connect site.
Here is a table that lists the SCCM Configuration Manager Technical Preview build numbers. The link points to the capabilities offered in each version. This table will be updated as and when the new versions are released.
Technical Preview Version
Site Version
DescriptionRelease Date
SCCM Technical Preview (Version 1809)5.0.8717.1000Link2018-09-12
SCCM Technical Preview (Version 1808)5.0.8707.1000Link2018-08-17
SCCM Technical Preview (Version 1807)5.0.8700.1000Link2018-07-30
SCCM Technical Preview (Version 1806.2)5.0.8685.1000Link2018-06-27
SCCM Technical Preview (Version 1806)5.0.8672.1000Link2018-06-04
SCCM Technical Preview (Version 1805)5.0.8659.1000Link2018-05-11
SCCM Technical Preview (Version 1804)5.0.8648.1000Link2018-04-24
SCCM Technical Preview (Version 1803)5.0.8636.1000Link2018-03-27
SCCM Technical Preview (Version 1802)5.0.8627.1000Link2018-02-09
SCCM Technical Preview (Version 1801)5.0.8611.1000Link2018-01-22
SCCM Technical Preview (Version 1712)5.0.8595.1000Link2017-12-16
SCCM Technical Preview (Version 1711)5.0.8582.1000Link2017-11-17
SCCM Technical Preview (Version 1710)5.0.8570.1000Link2017-10-30
SCCM Technical Preview (Version 1709)5.0.8559.1000Link2017-09-28
SCCM Technical Preview (Version 1708)5.0.8549.1000Link2017-08-26
SCCM Technical Preview (Version 1707)5.0.8542.1000Link2017-07-28
SCCM Technical Preview (Version 1706)5.0.8533.1000Link2017-06-25
SCCM Technical Preview (Version 1705)5.0.8525.1000Link2017-06-03
SCCM Technical Preview (Version 1704)5.0.8514.1000Link2017-04-21
SCCM Technical Preview (Version 1703)5.0.8506.1000Link2017-03-31
SCCM Technical Preview (Version 1702)5.0.8496.1000Link2017-02-24
SCCM Technical Preview (Version 1701)5.0.8482.1000Link2017-01-21
SCCM Technical Preview (Version 1612)5.0.8471.1000 Link2016-12-16
SCCM Technical Preview (Version 1611)5.0.8465.1000 Link2016-11-23
SCCM Technical Preview (Version 1610)5.0.8455.1000 Link2016-10-23
SCCM Technical Preview (Version 1609)5.0.8455.1000 Link2016-09-27
SCCM Technical Preview (Version 1608)5.0.8433.1000 Link2016-08-22
SCCM Technical Preview (Version 1607)5.0.8426.1000 Link2016-07-29
SCCM Technical Preview (Version 1606)5.0.8410.1000 Link2016-06-21
SCCM Technical Preview (Version 1605)5.0.8396.1000 Link2016-05-16
SCCM Technical Preview (Version 1604)5.0.8385.1000 Link2016-04-21
SCCM Technical Preview (Version 1603)5.0.8372.1000 Link 2016-03-17
SCCM Technical Preview (Version 1602)5.0.8360.1000 Link2016-02-17
SCCM Technical Preview (Version 1601)5.0.8347.1000 Link 2016-01-21
SCCM Technical Preview (Version 1512)5.0.8336.1000 Link2015-12-18
SCCM Technical Preview (Version 1511)5.0.8325.1000 Link2015-11-12
SCCM Technical Preview (Version 1510)5.0.8315.1000 Link2015-10-14
SCCM Technical Preview (Version 1509)5.0.8299.1000Link2015-09-22
SCCM Technical Preview 35.0.8287.1000Link 2015-08-19
SCCM Technical Preview 25.0.8271.1000Link2015-06-09
SCCM Technical Preview5.0.8239.1000Link2015-05-04
