SCCM SQL Query for Microsoft Office 32 Bit and 64 Bit
dark_blb
This post contains the SCCM SQL query for Microsoft office 32 bit and 64 bit. Many organizations today use Microsoft office to simply the work. Listing out office versions installed on all machines is a big task. Using SQL queries it’s very easy to find out the Office versions. However note that these are the SQL queries and not the WQL queries. Here is a forum thread that lists the difference between SQL and WQL queries.
The below query lists the 32 bit versions of office installed on machines.
SELECT DISTINCT v_GS_SYSTEM.Name0, v_GS_ADD_REMOVE_PROGRAMS.DisplayName0
FROM v_GS_SYSTEM INNER JOIN v_GS_ADD_REMOVE_PROGRAMS ON v_GS_SYSTEM.ResourceID = v_GS_ADD_REMOVE_PROGRAMS.ResourceID
WHERE (v_GS_ADD_REMOVE_PROGRAMS.DisplayName0) LIKE '%Microsoft % Standard%' or
(v_GS_ADD_REMOVE_PROGRAMS.DisplayName0) Like 'Microsoft % Professional%' or
(v_GS_ADD_REMOVE_PROGRAMS.DisplayName0) LIke 'Microsoft % Enterprise %'
The below query lists the 64 bit versions of office installed on machines.
SELECT DISTINCT v_GS_SYSTEM.Name0, v_GS_ADD_REMOVE_PROGRAMS_64.DisplayName0
FROM v_GS_SYSTEM INNER JOIN v_GS_ADD_REMOVE_PROGRAMS_64 ON v_GS_SYSTEM.ResourceID = v_GS_ADD_REMOVE_PROGRAMS_64.ResourceID
WHERE (v_GS_ADD_REMOVE_PROGRAMS_64.DisplayName0) LIKE '%Microsoft Office Standard%' or
(v_GS_ADD_REMOVE_PROGRAMS_64.DisplayName0) Like 'Microsoft Office Professional%'or
(v_GS_ADD_REMOVE_PROGRAMS_64.DisplayName0) LIke 'Microsoft Office Enterprise %'
If you are looking for a query that lists both 32 bit and 64 bit versions of Microsoft office installed, here it is. The query also fetches and displays the installed date as well.
SELECT DISTINCT
  SYS.Name0
  ,ARP.DisplayName0 As 'Software Name'
  ,ARP.Version0 As 'Version'
  ,ARP.InstallDate0 As 'Installed Date'
 FROM
  dbo.v_R_System As SYS
  INNER JOIN dbo.v_FullCollectionMembership FCM On FCM.ResourceID = SYS.ResourceID
  INNER JOIN dbo.v_Add_REMOVE_PROGRAMS As ARP On SYS.ResourceID = ARP.ResourceID
 WHERE
 (ARP.DisplayName0 LIKE '%Microsoft % Standard%'
 OR ARP.DisplayName0 LIKE 'Microsoft % Professional%'
 OR ARP.DisplayName0 LIKE 'Microsoft % Enterprise %')
 ORDER BY Name0 ASC
