CCMSetup failed with error code 0x87d0029e
CCMSetup failed with error code 0x87d0029e – I was working on a new SCCM deployment for a customer. After a week the SCCM deployment was done successfully. I handed it over to the customer after doing some basic configuration specified by customer. However after few days the I got an issue from customer end. The customer reported that client push installation is not working. During the client push installation the error found was ccmsetup failed with error code 0x87d0029e. The client agent installation failed with same error even with manual installation. So digging up the error from log file and error screenshot looked something like this.
Site version ‘5.00.7958.1000’ is compatible. Client deployment will continue.
Successfully downloaded client files via BITS.
Validated file ‘C:\Windows\ccmsetup\vcredist_x86.exe’
A Fallback Status Point has not been specified.
CcmSetup failed with error code 0x87d0029e
CCMSetup failed with error code 0x87d0029eTroubleshooting CCMSetup failed with error code 0x87d0029e
To fix this error you could try the below steps.
  1. In most cases deleting the ccmsetup folder and installing the client agent resolves this issue. The errors comes up due to corrupt components inside the ccmsetup folder. The ccmsetup folder is located under C:\Windows. Therefore delete the ccmsetup folder and try pushing the client agent.
  2. Launch command prompt as Administrator. Type net stop winmgmt /y and press enter. Change the path to C:\windows\system32\wbem and rename the folder repository to repository.old. To do this use the command: rename repository repository.old. Next start the winmgmt process using net start winmgmt command. Winmgmt is WMI service within the SVCHOST process running under the LocalSystem account. Close the command prompt. Now try pushing the SCCM client agent and it should work well.
If the above solution did not help you, let me know it via comments. If you have any other client agent installation issue, feel free to create support thread at community forums.
18 Comments
  1. It can be a hash mismatch in the Configuration Manager Client Package located in YourSiteServer:C:\Program Files\Microsoft Configuration Manager\Client\x64\ from where you serve the Configuration Manager Client Package, more precisely in its manifest ccmsetup.cab. In my case \Client\x64\vcredist_x64.exe was older than the one mentioned in the manifest. Compare the hash value of the vcredist_x64.exe with the value in the manifest. If wrong, it confirms the 0x87d0029e error in YourClient:C:\Windows\ccmsetup\Logs\ccmsetup.log. The mismatch will also be mentioned in ccmsetup .log. Look for a line that looks like this: File ‘C:\WINDOWS\ccmsetup\vcredist_x64.exe’ with hash ‘1821577409C35B2B9505AC833E246376CC68A8262972100444010B57226F0940′ from manifest doesn’t match with the file hash ’52B196BBE9016488C735E7B41805B651261FFA5D7AA86EB6A1D0095BE83687B2’ ccmsetup
    To solve this you want to go to your CM site server and run this one-liner: Get-ChildItem ‘C:\Program Files\Microsoft Configuration Manager’,’C:\Program Files (x86)\Microsoft Configuration Manager’ -Recurse -Include vcredist*.exe -ErrorAction SilentlyContinue | ForEach-Object { “{0} {1}” -f (Get-FileHash $_.FullName -Algorithm SHA256).Hash, $_.FullName }
    Compare the hashes in the list with the one in the manifest in Client\x64\setupccm.cab. Now replace the Client\x64\vcredist_x64.exe (this one has the bad hash) with the correct hashed one. Update the distribution points and re-run the TS.
    How such a mismatch can happen? Just so? If I only knew.
  2. Avatar photo shanthini says:
    Still i am getting the same issue
  3. Avatar photo shanthini says:
    Still iam getting the same issue
  4. reinstall vcredits from other location and reinstall sccm client.
    Problem resolved.
  5. #2 worked for me, but I had to go about it a little different on a couple clients. Just remember your ultimate goal is to get WMI and it’s associated services stopped and stay stopped to allow your to rename the Repository folder before any of the services start again. Trying to stop the WMI service did not work by command or manually through services. 1 client, had to reboot the system, stop services Security Center, SMS Host Agent, IP Helper, then the WMI service before I could rename the folder and restart the service. On the other client, the WMI kept starting on its own and got stuck in Stopping too. Got all services in stopped state and/or in the stuck stopping state. Set them all to Disabled (remember their original settings for later), reboot the system, rename the folder, then set the services back to Automatic and Automatic (delayed). Started WMI, then IP Helper, then SMS Host Agent, then Security Center. The system took the client and checked in with SCCM.
  6. CcmSetup failed with error code 0x87d00227 im am getting this error at the time of SCCM client installation time.
  7. Avatar photo Dominic Tyner says:
    Thank you! I continue to come to your site for help!
  8. Avatar photo Fernando the IT says:
    Thanks so much, I was dealing with this issue for days, once I ran these commands it worked like magic, thanks so much once again
  9. Avatar photo Hugo Martinez Peregrina says:
    after Rebuild WMI I am still getting the same error on the machine
    Here the CCMsetup.log
    <![LOG[]LOG]!>
    1. I don’t see the error code, I need full log file. What’s in ccm.log file ?.
      1. Avatar photo Hugo Martinez Peregrina says:
        Thanks for take a look, here the CCMSETUP.log on onedrive
        component=”ccmsetup” context=”” type=”0″ thread=”11940″ file=”util.cpp:2690″>
        <![LOG[
        ]LOG]!>
      2. Avatar photo Hugo Martinez Peregrina says:
      3. Avatar photo Hugo Martinez Peregrina says:
        Hi Prajwal
        Thanks for take a look on it
        I am updating the ccmsetup.log
        but somehow my post is disappearing
      4. Avatar photo Hugo Martinez Peregrina says:
        I am sharing the log on a onedrive link but look like is being erased
        Are onedrive links not allowed?
      5. Avatar photo Hugo Martinez Peregrina says:
        well I finally solve issue copying source client installation files from a different repository so looks to be a corruption issue with one of those files
  10. After updating to 1610 ALL of our deployments with fresh images are having this issue. Basically it will fail as soon as it get to the install step of the “Config. Manager Client Package” it will download but then goes straight into windows.
    (Log File if needed or curious)
    1. Thanks for sending the log files. I see the files required to install client agent are downloaded but the issue occurs during the installation. Can you confirm if you have deleted the ccmsetup folder and tried it ?.
      1. Sorry for the late response. We actually ended setting up a new SCCM server since our 2008 server was going to be no longer supported.
