Configuration Manager SCCM 1710 Update Rollup 2 KB4086143
Posted by Prajwal Desai
Yes you heard it right, SCCM 1710 update rollup 2 is released. Wait a minute, did we notice rollup 1 released recently ?. You might be wondering that there was a rollup 1 for SCCM 1710 released in January, KB4057517. While it’s not even two months, we see another rollup KB4086143 released for SCCM current branch 1710.
This update brings lot of improvement and fixes over SCCM current branch rollup 1. The fixes are described here. Just a quick note, this update replaces previously released updates 4057517 and 4088970. So if you had not installed these two updates, you can skip them and directly install SCCM update rollup 2 KB4086143.
You can download and install this update under Updates and Servicing node of SCCM console. The SCCM Configuration Manager build numbers are documented here. You must install this update first on primary sites. Furthermore pre-existing secondary sites should be manually updated.
I will show some screenshots that will help you install SCCM update rollup 2 KB4086143. I am sure you would know these steps, I have skipped some screens to make it quick. Go to Administration > Cloud Services > Updates and Servicing. If you don’t see the hotfix, click Check for updates. Once you see the update, select the update, right click and click Install Update Pack.
You will now see updates installation wizard. On General page click Next. Accept the license terms and click Next on Summary and Progress page. Finally on Completion page click Close.
To monitor the installation of SCCM 1710 update rollup 2, go to Monitoring > Site Servicing Status. Right-click update and select Show Status. You can also open CMUpdate.log file using CM trace log tool to monitor rollup installation.
Post the installation of hotfix rollup, refresh the console. Click OK to update existing console from version 5.00.8577.1108 to 5.00.8577.1115.
Click Finish to complete the console upgrade.
Checking About System Center Configuration Manager shows the following.
Version – 1710
Console version – 5.00.8577.1115
Site version – 5.0.8577.1000
Click OK to close the box.
Updating Clients with SCCM 1710 Update rollup 2
To update clients with SCCM 1710 update rollup 2 you should enable client upgrade feature under Hierarchy Settings. Check the box Upgrade all clients in the hierarchy using production client. Set the number of days for client agents to upgrade and click OK. If you need to know more about this, check this post.
Share This Article
Follow:
9 Comments
