SCCM 1806 Hotfix Rollup KB4462978 – Fixes and Installation
If you running Configuration Manager version 1806, then there is an update waiting in the console. I am talking update rollup for System Center Configuration Manager current branch, version 1806. SCCM 1806 Hotfix Rollup KB4462978 contains a heap of fixes. If you are planning to upgrade your SCCM to SCCM 1806, here is the SCCM 1806 upgrade guide.
If you have got secondary sites, install this update on a primary site first. And then for secondary sites, the update must be installed manually. As per Microsoft, This update replaces updates KB4346645 or KB4459354 depending on the different first wave version. In addition, this update also covers the previous hotfix 4465865.
SCCM 1806 Hotfix Rollup KB4462978 – List of Fixes
SCCM 1806 Hotfix Rollup KB4462978 contains several fixes. Mentioning all of them here would be redundant because it is already documented by Microsoft. So here is the screenshot of those fixes. The first set of fixes are in the below screenshot.
SCCM 1806 Hotfix Rollup KB4462978 Fixes – Copyright Microsoft
Below is the second list of fixes included with KB4462978.
SCCM 1806 Hotfix Rollup KB4462978 – Installation
  • Click Administration > Overview > Updates and Servicing.
  • Right click Configuration Manager 1806 Hotfix Rollup (KB4462978).
  • Click Install Update Pack.
Click Next on Summary and Progress page. On the completion page, click Close.
Monitor the hotfix rollup installation in Monitoring  > Updates and Servicing Status.
Refresh the console once and you get a box to upgrade SCCM console. The console version will be upgraded from 5.1806.1074.1500 to 5.1806.1074.1507. Click OK to begin the upgrade.
Let’s check console version post installing the hotfix rollup KB4462978.
  • Version – 1806
  • Console Version – 5.1806.1074.1507
  • Site Version – 5.0.8692.1000
Note – There is no change in the build and site version number.
